Time Before: 0.00731 seconds
Time After: 0.00923 seconds
Time Taken: 0.00192 seconds
Memory Before: 529.984 KB
Memory After: 555.039 KB
Memory Used: 25.055 KB
Time Before: 0.00932 seconds
Time After: 0.01003 seconds
Time Taken: 0.00070 seconds
Memory Before: 554.977 KB
Memory After: 555.984 KB
Memory Used: 1.008 KB
SET @@sql_mode = ''
Time Before: 0.01027 seconds
Time After: 0.01042 seconds
Time Taken: 0.00015 seconds
Memory Before: 556.578 KB
Memory After: 557.102 KB
Memory Used: 0.523 KB
SELECT *
FROM datastore
WHERE title IN ('smiliecache','bbcodecache','mailqueue','bookmarksitecache','navdata','options','bitfields','attachmentcache','forumcache','usergroupcache','stylecache','languagecache','products','pluginlist','cron','profilefield','loadcache','noticecache','activitystream','routes')| id | select_type | table | type | possible_keys | key | key_len | ref | rows | Extra |
| 1 | SIMPLE | datastore | range | PRIMARY | PRIMARY | 52 | 20 | Using where |
Time Before: 0.01110 seconds
Time After: 0.01423 seconds
Time Taken: 0.00313 seconds
Memory Before: 559.719 KB
Memory After: 560.625 KB
Memory Used: 0.906 KB
Time Before: 0.01047 seconds
Time After: 0.01771 seconds
Time Taken: 0.00724 seconds
Memory Before: 556.320 KB
Memory After: 1,648.492 KB
Memory Used: 1,092.172 KB
SELECT * FROM session WHERE userid = 0 AND host = '192.168.0.1' AND idhash = 'ce294c5626a6c3c128594a952859491f' LIMIT 1
| 1 | SIMPLE | session | ref | idhash,host,userid,guest_lookup,user_activity | idhash | 32 | const | 2 | Using where |
Time Before: 0.02067 seconds
Time After: 0.02108 seconds
Time Taken: 0.00041 seconds
Memory Before: 2,148.375 KB
Memory After: 2,148.992 KB
Memory Used: 0.617 KB
SELECT languageid, phrasegroup_global AS phrasegroup_global, phrasegroup_posting AS phrasegroup_posting, phrasegroup_postbit AS phrasegroup_postbit, phrasegroup_showthread AS phrasegroup_showthread, phrasegroup_inlinemod AS phrasegroup_inlinemod, phrasegroup_reputationlevel AS phrasegroup_reputationlevel, phrasegroupinfo AS lang_phrasegroupinfo, options AS lang_options, languagecode AS lang_code, charset AS lang_charset, locale AS lang_locale, imagesoverride AS lang_imagesoverride, dateoverride AS lang_dateoverride, timeoverride AS lang_timeoverride, registereddateoverride AS lang_registereddateoverride, calformat1override AS lang_calformat1override, calformat2override AS lang_calformat2override, logdateoverride AS lang_logdateoverride, decimalsep AS lang_decimalsep, thousandsep AS lang_thousandsep FROM language WHERE languageid = 3
| 1 | SIMPLE | language | system | PRIMARY | 1 |
Time Before: 0.02338 seconds
Time After: 0.02561 seconds
Time Taken: 0.00223 seconds
Memory Before: 2,160.477 KB
Memory After: 2,160.344 KB
Memory Used: -0.133 KB
Time Before: 0.02004 seconds
Time After: 0.02577 seconds
Time Taken: 0.00574 seconds
Memory Before: 2,140.086 KB
Memory After: 2,230.773 KB
Memory Used: 90.688 KB
SELECT IF(thread.visible = 2, 1, 0) AS isdeleted, post.pagetext AS description, thread.* FROM thread AS thread LEFT JOIN post AS post ON(post.postid = thread.firstpostid) WHERE thread.threadid = 374275 LIMIT 1
| 1 | SIMPLE | thread | const | PRIMARY | PRIMARY | 4 | const | 1 | |
| 1 | SIMPLE | post | const | PRIMARY | PRIMARY | 4 | const | 1 |
Time Before: 0.03803 seconds
Time After: 0.03844 seconds
Memory Before: 2,626.094 KB
Memory After: 2,626.703 KB
Memory Used: 0.609 KB
SELECT forum.*, NOT ISNULL(podcast.forumid) AS podcast FROM forum AS forum LEFT JOIN podcast AS podcast ON (forum.forumid = podcast.forumid AND podcast.enabled = 1) WHERE forum.forumid = 121 LIMIT 1
| 1 | SIMPLE | Impossible WHERE noticed after reading const tables |
Time Before: 0.03922 seconds
Time After: 0.03956 seconds
Time Taken: 0.00035 seconds
Memory Before: 2,637.273 KB
Memory After: 2,637.664 KB
Memory Used: 0.391 KB
SELECT MAX(permissions & 1) AS perm FROM cms_permissions WHERE nodeid = 1 AND usergroupid IN (1)
| 1 | SIMPLE | cms_permissions | const | usergroupid,nodeid | usergroupid | 8 | const,const | 1 |
Time Before: 0.04030 seconds
Time After: 0.04043 seconds
Time Taken: 0.00013 seconds
Memory Before: 2,648.625 KB
Memory After: 2,649.141 KB
Memory Used: 0.516 KB
SELECT * FROM style WHERE (styleid = 5 AND userselect = 1) OR styleid = 5 ORDER BY styleid ASC LIMIT 1
| 1 | SIMPLE | style | const | PRIMARY | PRIMARY | 2 | const | 1 |
Time Before: 0.04608 seconds
Time After: 0.04742 seconds
Time Taken: 0.00134 seconds
Memory Before: 2,736.992 KB
Memory After: 2,737.586 KB
Memory Used: 0.594 KB
Time Before: 0.05360 seconds
Time After: 0.05386 seconds
Time Taken: 0.00026 seconds
Memory Before: 3,440.898 KB
Memory After: 3,441.289 KB
SELECT text, languageid, special FROM phrase AS phrase LEFT JOIN phrasetype USING (fieldname) WHERE phrase.fieldname = 'error' AND varname = 'nopermission_loggedout' AND languageid IN (-1, 0, 3)
| 1 | SIMPLE | phrase | range | name_lang_type,languageid | name_lang_type | 276 | 3 | Using where | |
| 1 | SIMPLE | phrasetype | const | PRIMARY | PRIMARY | 22 | const | 1 |
Time Before: 0.05542 seconds
Time After: 0.05621 seconds
Time Taken: 0.00079 seconds
Memory Before: 3,450.625 KB
Memory After: 3,451.055 KB
Memory Used: 0.430 KB
SELECT title, template FROM template WHERE templateid IN (38969,38968,57230,57237,62286,61860,61861,61863,61869,61868,53515,62067,62053,62054,62056,62055,62058,62060,62061,62062,62065,61760,61762,61764,61766,55011,55010,62121,32951,62123,62120,62190,62041,62040,62042,62047,62045,62214,61822,61823,61989,61816,47496,61818,61819,61832,55009,55071,57273,57295,62316,0,0,6082,38961,42855,57213,38966,57292,5992,62031,62305,45486,61981,53288,61979,61980,62335,0,0,62315,62276,62001,62002,62004,62005,62228,62347,62329,62279,62280,61828,61827,61831,61391,61392,61390,61659)
| 1 | SIMPLE | template | range | PRIMARY | PRIMARY | 4 | 85 | Using where |
Time Before: 0.05966 seconds
Time After: 0.06268 seconds
Time Taken: 0.00301 seconds
Memory Before: 3,735.992 KB
Memory After: 3,738.000 KB
Memory Used: 2.008 KB
UPDATE session SET lastactivity = 1779107500, location = '/forum/threads/374275-�Ҥ�-3S-GE-�Ѻ-2ZZ-VVTLi?explain=1', badlocation = 1 WHERE sessionhash = '55d8adcdd3badb784fae71d5f5ee1695'
Time Before: 0.07906 seconds
Time After: 0.07938 seconds
Time Taken: 0.00032 seconds
Memory Before: 4,249.188 KB
Memory After: 4,249.391 KB
Memory Used: 0.203 KB
