Including Functions.php
Time Before: 0.02688 seconds
Time After: 0.03230 seconds
Time Taken: 0.00542 seconds
Memory Before: 528.180 KB
Memory After: 553.234 KB
Memory Used: 25.055 KB
Connect to Database on Server: 192.168.0.20
Time Before: 0.03239 seconds
Time After: 0.03320 seconds
Time Taken: 0.00081 seconds
Memory Before: 553.172 KB
Memory After: 554.180 KB
Memory Used: 1.008 KB
SQL Query
SET @@sql_mode = ''
Time Before: 0.03344 seconds
Time After: 0.03378 seconds
Time Taken: 0.00033 seconds
Memory Before: 554.766 KB
Memory After: 555.289 KB
Memory Used: 0.523 KB
Datastore Setup
SQL Query
SELECT *
FROM datastore
WHERE title IN ('smiliecache','bbcodecache','mailqueue','bookmarksitecache','navdata','options','bitfields','attachmentcache','forumcache','usergroupcache','stylecache','languagecache','products','pluginlist','cron','profilefield','loadcache','noticecache','activitystream','routes')
idselect_typetabletypepossible_keyskeykey_lenrefrowsExtra
1SIMPLEdatastorerangePRIMARYPRIMARY52 20Using where
Time Before: 0.03459 seconds
Time After: 0.03779 seconds
Time Taken: 0.00320 seconds
Memory Before: 557.906 KB
Memory After: 558.813 KB
Memory Used: 0.906 KB
Time Before: 0.03385 seconds
Time After: 0.04340 seconds
Time Taken: 0.00955 seconds
Memory Before: 554.508 KB
Memory After: 1,646.719 KB
Memory Used: 1,092.211 KB
Session Handling
SQL Query
SELECT *
FROM session
WHERE userid = 0
	AND host = '192.168.0.1'
	AND idhash = 'ce294c5626a6c3c128594a952859491f'
LIMIT 1
1SIMPLEsessionrefidhash,host,userid,guest_lookup,user_activityidhash32const2Using where
Time Before: 0.05208 seconds
Time After: 0.05235 seconds
Time Taken: 0.00027 seconds
Memory Before: 2,146.609 KB
Memory After: 2,147.227 KB
Memory Used: 0.617 KB
SQL Query
SELECT languageid,
			phrasegroup_global AS phrasegroup_global,
			phrasegroup_posting AS phrasegroup_posting,
			phrasegroup_postbit AS phrasegroup_postbit,
			phrasegroup_showthread AS phrasegroup_showthread,
			phrasegroup_inlinemod AS phrasegroup_inlinemod,
			phrasegroup_reputationlevel AS phrasegroup_reputationlevel,
			phrasegroupinfo AS lang_phrasegroupinfo,
			options AS lang_options,
			languagecode AS lang_code,
			charset AS lang_charset,
			locale AS lang_locale,
			imagesoverride AS lang_imagesoverride,
			dateoverride AS lang_dateoverride,
			timeoverride AS lang_timeoverride,
			registereddateoverride AS lang_registereddateoverride,
			calformat1override AS lang_calformat1override,
			calformat2override AS lang_calformat2override,
			logdateoverride AS lang_logdateoverride,
			decimalsep AS lang_decimalsep,
			thousandsep AS lang_thousandsep
FROM language
WHERE languageid = 3
1SIMPLElanguagesystemPRIMARY   1
Time Before: 0.05501 seconds
Time After: 0.05824 seconds
Time Taken: 0.00323 seconds
Memory Before: 2,158.609 KB
Memory After: 2,158.477 KB
Memory Used: -0.133 KB
Time Before: 0.05146 seconds
Time After: 0.05846 seconds
Time Taken: 0.00700 seconds
Memory Before: 2,138.320 KB
Memory After: 2,229.234 KB
Memory Used: 90.914 KB
SQL Query
SELECT IF(thread.visible = 2, 1, 0) AS isdeleted,
post.pagetext AS description,
thread.*
FROM thread AS thread
LEFT JOIN post AS post ON(post.postid = thread.firstpostid)
WHERE thread.threadid = 470357 LIMIT 1
1SIMPLEthreadconstPRIMARYPRIMARY4const1
1SIMPLEpostconstPRIMARYPRIMARY4const1
Time Before: 0.12470 seconds
Time After: 0.12525 seconds
Time Taken: 0.00055 seconds
Memory Before: 2,624.555 KB
Memory After: 2,625.164 KB
Memory Used: 0.609 KB
SQL Query
SELECT forum.*, NOT ISNULL(podcast.forumid) AS podcast
FROM forum AS forum
LEFT JOIN podcast AS podcast ON (forum.forumid = podcast.forumid AND podcast.enabled = 1)
WHERE forum.forumid = 55 LIMIT 1
1SIMPLE       Impossible WHERE noticed after reading const tables
Time Before: 0.12590 seconds
Time After: 0.12623 seconds
Time Taken: 0.00034 seconds
Memory Before: 2,636.695 KB
Memory After: 2,637.086 KB
Memory Used: 0.391 KB
SQL Query
SELECT MAX(permissions & 1) AS perm
FROM cms_permissions
WHERE nodeid = 1 AND usergroupid IN (1)
1SIMPLEcms_permissionsconstusergroupid,nodeidusergroupid8const,const1
Time Before: 0.12701 seconds
Time After: 0.12716 seconds
Time Taken: 0.00014 seconds
Memory Before: 2,648.055 KB
Memory After: 2,648.570 KB
Memory Used: 0.516 KB
Warning: session_start(): Cannot send session cookie - headers already sent by (output started at /data/vhosts/rcw.ms/htdocs/forums/includes/class_database_explain.php:332) in /data/vhosts/rcw.ms/htdocs/forums/includes/facebook/facebook.php on line 49 Warning: session_start(): Cannot send session cache limiter - headers already sent (output started at /data/vhosts/rcw.ms/htdocs/forums/includes/class_database_explain.php:332) in /data/vhosts/rcw.ms/htdocs/forums/includes/facebook/facebook.php on line 49
SQL Query
SELECT *
FROM style
WHERE (styleid = 5 AND userselect = 1)
	OR styleid = 5
ORDER BY styleid ASC
LIMIT 1
1SIMPLEstyleconstPRIMARYPRIMARY2const1
Time Before: 0.14222 seconds
Time After: 0.14350 seconds
Time Taken: 0.00128 seconds
Memory Before: 2,736.516 KB
Memory After: 2,737.109 KB
Memory Used: 0.594 KB
End call of global.php: 0.14581894874573
SQL Query
FROM forum AS forum
Time Before: 0.16248 seconds
Time After: 0.16271 seconds
Time Taken: 0.00023 seconds
Memory Before: 3,440.852 KB
Memory After: 3,441.242 KB
SQL Query
SELECT text, languageid, special
FROM phrase AS phrase
LEFT JOIN phrasetype USING (fieldname)
WHERE phrase.fieldname = 'error'
	AND varname = 'nopermission_loggedout' AND languageid IN (-1, 0, 3)
1SIMPLEphraserangename_lang_type,languageidname_lang_type276 3Using where
1SIMPLEphrasetypeconstPRIMARYPRIMARY22const1
Time Before: 0.16879 seconds
Time After: 0.16895 seconds
Time Taken: 0.00015 seconds
Memory Before: 3,450.578 KB
Memory After: 3,451.008 KB
Memory Used: 0.430 KB
SQL Query
SELECT title, template
FROM template
WHERE templateid IN (38969,38968,57230,57237,62286,61860,61861,61863,61869,61868,53515,62067,62053,62054,62056,62055,62058,62060,62061,62062,62065,61760,61762,61764,61766,55011,55010,62121,32951,62123,62120,62190,62041,62040,62042,62047,62045,62214,61822,61823,61989,61816,47496,61818,61819,61832,55009,55071,57273,57295,62316,0,0,6082,38961,42855,57213,38966,57292,5992,62031,62305,45486,61981,53288,61979,61980,62335,0,0,62315,62276,62001,62002,62004,62005,62228,62347,62329,62279,62280,61828,61827,61831,61391,61392,61390,61659)
1SIMPLEtemplaterangePRIMARYPRIMARY4 85Using where
Time Before: 0.17188 seconds
Time After: 0.17424 seconds
Time Taken: 0.00236 seconds
Memory Before: 3,735.945 KB
Memory After: 3,737.953 KB
Memory Used: 2.008 KB
SQL Query
UPDATE session
SET location = '/forum/threads/470357-�ش�-�Ѻ�ҹNissan-Society-Thailand?explain=1', badlocation = 1
WHERE sessionhash = '708f3049c6f4aeb346a0a4658c824d43'
Time Before: 0.19541 seconds
Time After: 0.19564 seconds
Memory Before: 4,253.430 KB
Memory After: 4,253.648 KB
Memory Used: 0.219 KB
Page generated in 0.1941978931427 seconds with 12 queries, spending 0.01313328742981 doing MySQL queries and 0.18106460571289 doing PHP things.
Shutdown Queries:
DISABLED
