Including Functions.php
Time Before: 0.01312 seconds
Time After: 0.01835 seconds
Time Taken: 0.00523 seconds
Memory Before: 529.914 KB
Memory After: 554.969 KB
Memory Used: 25.055 KB
Connect to Database on Server: 192.168.0.20
Time Before: 0.01844 seconds
Time After: 0.01953 seconds
Time Taken: 0.00109 seconds
Memory Before: 554.906 KB
Memory After: 555.914 KB
Memory Used: 1.008 KB
SQL Query
SET @@sql_mode = ''
Time Before: 0.01983 seconds
Time After: 0.01994 seconds
Time Taken: 0.00011 seconds
Memory Before: 556.500 KB
Memory After: 557.023 KB
Memory Used: 0.523 KB
Datastore Setup
SQL Query
SELECT *
FROM datastore
WHERE title IN ('smiliecache','bbcodecache','mailqueue','bookmarksitecache','navdata','options','bitfields','attachmentcache','forumcache','usergroupcache','stylecache','languagecache','products','pluginlist','cron','profilefield','loadcache','noticecache','activitystream','routes')
idselect_typetabletypepossible_keyskeykey_lenrefrowsExtra
1SIMPLEdatastorerangePRIMARYPRIMARY52 20Using where
Time Before: 0.02080 seconds
Time After: 0.02372 seconds
Time Taken: 0.00292 seconds
Memory Before: 559.641 KB
Memory After: 560.547 KB
Memory Used: 0.906 KB
Time Before: 0.02002 seconds
Time After: 0.02754 seconds
Time Taken: 0.00753 seconds
Memory Before: 556.242 KB
Memory After: 1,648.430 KB
Memory Used: 1,092.188 KB
Session Handling
SQL Query
SELECT *
FROM session
WHERE userid = 0
	AND host = '192.168.0.1'
	AND idhash = 'ce294c5626a6c3c128594a952859491f'
LIMIT 1
1SIMPLEsessionrefidhash,host,userid,guest_lookup,user_activityidhash32const2Using where
Time Before: 0.03480 seconds
Time After: 0.03518 seconds
Time Taken: 0.00038 seconds
Memory Before: 2,148.313 KB
Memory After: 2,148.930 KB
Memory Used: 0.617 KB
SQL Query
SELECT languageid,
			phrasegroup_global AS phrasegroup_global,
			phrasegroup_posting AS phrasegroup_posting,
			phrasegroup_postbit AS phrasegroup_postbit,
			phrasegroup_showthread AS phrasegroup_showthread,
			phrasegroup_inlinemod AS phrasegroup_inlinemod,
			phrasegroup_reputationlevel AS phrasegroup_reputationlevel,
			phrasegroupinfo AS lang_phrasegroupinfo,
			options AS lang_options,
			languagecode AS lang_code,
			charset AS lang_charset,
			locale AS lang_locale,
			imagesoverride AS lang_imagesoverride,
			dateoverride AS lang_dateoverride,
			timeoverride AS lang_timeoverride,
			registereddateoverride AS lang_registereddateoverride,
			calformat1override AS lang_calformat1override,
			calformat2override AS lang_calformat2override,
			logdateoverride AS lang_logdateoverride,
			decimalsep AS lang_decimalsep,
			thousandsep AS lang_thousandsep
FROM language
WHERE languageid = 3
1SIMPLElanguagesystemPRIMARY   1
Time Before: 0.03670 seconds
Time After: 0.03858 seconds
Time Taken: 0.00188 seconds
Memory Before: 2,160.414 KB
Memory After: 2,160.281 KB
Memory Used: -0.133 KB
Time Before: 0.03415 seconds
Time After: 0.03883 seconds
Time Taken: 0.00467 seconds
Memory Before: 2,140.023 KB
Memory After: 2,230.711 KB
Memory Used: 90.688 KB
SQL Query
SELECT IF(thread.visible = 2, 1, 0) AS isdeleted,
post.pagetext AS description,
thread.*
FROM thread AS thread
LEFT JOIN post AS post ON(post.postid = thread.firstpostid)
WHERE thread.threadid = 952527 LIMIT 1
1SIMPLEthreadconstPRIMARYPRIMARY4const1
1SIMPLEpostconstPRIMARYPRIMARY4const1
Time Before: 0.07234 seconds
Time After: 0.07287 seconds
Time Taken: 0.00053 seconds
Memory Before: 2,626.008 KB
Memory After: 2,626.617 KB
Memory Used: 0.609 KB
SQL Query
SELECT forum.*, NOT ISNULL(podcast.forumid) AS podcast
FROM forum AS forum
LEFT JOIN podcast AS podcast ON (forum.forumid = podcast.forumid AND podcast.enabled = 1)
WHERE forum.forumid = 146 LIMIT 1
1SIMPLE       Impossible WHERE noticed after reading const tables
Time Before: 0.07349 seconds
Time After: 0.07391 seconds
Time Taken: 0.00042 seconds
Memory Before: 2,637.703 KB
Memory After: 2,638.094 KB
Memory Used: 0.391 KB
SQL Query
SELECT MAX(permissions & 1) AS perm
FROM cms_permissions
WHERE nodeid = 1 AND usergroupid IN (1)
1SIMPLEcms_permissionsconstusergroupid,nodeidusergroupid8const,const1
Time Before: 0.07476 seconds
Time After: 0.07488 seconds
Time Taken: 0.00012 seconds
Memory Before: 2,649.047 KB
Memory After: 2,649.563 KB
Memory Used: 0.516 KB
Warning: session_start(): Cannot send session cache limiter - headers already sent (output started at /data/vhosts/rcw.ms/htdocs/forums/includes/class_database_explain.php:332) in /data/vhosts/rcw.ms/htdocs/forums/includes/facebook/facebook.php on line 49
SQL Query
SELECT *
FROM style
WHERE (styleid = 5 AND userselect = 1)
	OR styleid = 5
ORDER BY styleid ASC
LIMIT 1
1SIMPLEstyleconstPRIMARYPRIMARY2const1
Time Before: 0.08588 seconds
Time After: 0.08721 seconds
Time Taken: 0.00134 seconds
Memory Before: 2,737.422 KB
Memory After: 2,738.016 KB
Memory Used: 0.594 KB
End call of global.php: 0.089273929595947
SQL Query
FROM forum AS forum
Time Before: 0.10105 seconds
Time After: 0.10124 seconds
Time Taken: 0.00019 seconds
Memory Before: 3,441.375 KB
Memory After: 3,441.766 KB
SQL Query
SELECT text, languageid, special
FROM phrase AS phrase
LEFT JOIN phrasetype USING (fieldname)
WHERE phrase.fieldname = 'error'
	AND varname = 'nopermission_loggedout' AND languageid IN (-1, 0, 3)
1SIMPLEphraserangename_lang_type,languageidname_lang_type276 3Using where
1SIMPLEphrasetypeconstPRIMARYPRIMARY22const1
Time Before: 0.10599 seconds
Time After: 0.10670 seconds
Time Taken: 0.00071 seconds
Memory Before: 3,451.102 KB
Memory After: 3,451.531 KB
Memory Used: 0.430 KB
SQL Query
SELECT title, template
FROM template
WHERE templateid IN (38969,38968,57230,57237,62286,61860,61861,61863,61869,61868,53515,62067,62053,62054,62056,62055,62058,62060,62061,62062,62065,61760,61762,61764,61766,55011,55010,62121,32951,62123,62120,62190,62041,62040,62042,62047,62045,62214,61822,61823,61989,61816,47496,61818,61819,61832,55009,55071,57273,57295,62316,0,0,6082,38961,42855,57213,38966,57292,5992,62031,62305,45486,61981,53288,61979,61980,62335,0,0,62315,62276,62001,62002,62004,62005,62228,62347,62329,62279,62280,61828,61827,61831,61391,61392,61390,61659)
1SIMPLEtemplaterangePRIMARYPRIMARY4 85Using where
Time Before: 0.10916 seconds
Time After: 0.11148 seconds
Time Taken: 0.00232 seconds
Memory Before: 3,736.469 KB
Memory After: 3,738.477 KB
Memory Used: 2.008 KB
SQL Query
UPDATE session
SET lastactivity = 1782859689, location = '/forum/threads/952527-�ѹ�ٿ-nissan-presea-r11?explain=1', badlocation = 1
WHERE sessionhash = '708f3049c6f4aeb346a0a4658c824d43'
Time Before: 0.13182 seconds
Time After: 0.13210 seconds
Time Taken: 0.00029 seconds
Memory Before: 4,249.867 KB
Memory After: 4,250.063 KB
Memory Used: 0.195 KB
Page generated in 0.12999391555786 seconds with 12 queries, spending 0.012281656265259 doing MySQL queries and 0.1177122592926 doing PHP things.
Shutdown Queries:
DISABLED
