Time Before: 0.00186 seconds
Time After: 0.00232 seconds
Time Before: 0.00239 seconds
Time After: 0.00272 seconds
Time Before: 0.00294 seconds
Time After: 0.00305 seconds
Time Taken: 0.00010 seconds
Time Before: 0.00384 seconds
Time After: 0.00725 seconds
Time Taken: 0.00340 seconds
Time Before: 0.00312 seconds
Time After: 0.01190 seconds
Time Taken: 0.00878 seconds
Time Before: 0.01396 seconds
Time After: 0.01423 seconds
Time Before: 0.01668 seconds
Time After: 0.01808 seconds
Time Taken: 0.00140 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.01344 seconds
Time After: 0.01825 seconds
Time Taken: 0.00482 seconds
Memory After: 2,261.820 KB
Time Before: 0.02425 seconds
Time After: 0.02439 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.02655 seconds
Time After: 0.02837 seconds
Time Taken: 0.00183 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
Time Before: 0.03130 seconds
Time After: 0.03141 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.03326 seconds
Time After: 0.03508 seconds
Time Taken: 0.00182 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
UPDATE session SET lastactivity = 1789070074, location = '/forums/private.php?do=newpm&explain=1&u=100004' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.04752 seconds
Time After: 0.04785 seconds
Memory Before: 4,287.563 KB
Memory After: 4,287.781 KB
