Time Before: 0.03070 seconds
Time After: 0.04277 seconds
Time Taken: 0.01207 seconds
Time Before: 0.04288 seconds
Time After: 0.04336 seconds
Time Before: 0.04363 seconds
Time After: 0.04377 seconds
Time Before: 0.04465 seconds
Time After: 0.04659 seconds
Time Taken: 0.00194 seconds
Time Before: 0.04384 seconds
Time After: 0.05072 seconds
Time Taken: 0.00688 seconds
Time Before: 0.06256 seconds
Time After: 0.06300 seconds
Time Before: 0.06560 seconds
Time After: 0.06681 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.06160 seconds
Time After: 0.06704 seconds
Time Taken: 0.00544 seconds
Memory After: 2,261.703 KB
Time Before: 0.11179 seconds
Time After: 0.11194 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.13161 seconds
Time After: 0.13331 seconds
Time Taken: 0.00170 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 0.14920 seconds
Time After: 0.14939 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.15211 seconds
Time After: 0.15366 seconds
Time Taken: 0.00155 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=100011', badlocation = 1 WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.16875 seconds
Time After: 0.16914 seconds
Memory Before: 4,287.469 KB
Memory After: 4,287.695 KB
