Time Before: 0.00170 seconds
Time After: 0.00221 seconds
Time Before: 0.00228 seconds
Time After: 0.00267 seconds
Time Before: 0.00288 seconds
Time After: 0.00302 seconds
Time Before: 0.00368 seconds
Time After: 0.00597 seconds
Time Taken: 0.00229 seconds
Time Before: 0.00307 seconds
Time After: 0.00950 seconds
Time Taken: 0.00643 seconds
Time Before: 0.01142 seconds
Time After: 0.01178 seconds
Time Before: 0.01417 seconds
Time After: 0.01542 seconds
Time Before: 0.01084 seconds
Time After: 0.01566 seconds
Time Taken: 0.00481 seconds
Time Before: 0.02275 seconds
Time After: 0.02301 seconds
Time Before: 0.02545 seconds
Time After: 0.02674 seconds
Time Before: 0.02970 seconds
Time After: 0.02984 seconds
Time Before: 0.03180 seconds
Time After: 0.03323 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=100025', badlocation = 1 WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.04688 seconds
Time After: 0.04714 seconds
