Time Before: 0.01739 seconds
Time After: 0.02303 seconds
Time Taken: 0.00564 seconds
Time Before: 0.02311 seconds
Time After: 0.02354 seconds
Time Before: 0.02375 seconds
Time After: 0.02386 seconds
Time Before: 0.02467 seconds
Time After: 0.02701 seconds
Time Taken: 0.00235 seconds
Time Before: 0.02394 seconds
Time After: 0.03120 seconds
Time Taken: 0.00726 seconds
Time Before: 0.04156 seconds
Time After: 0.04174 seconds
Time Before: 0.04437 seconds
Time After: 0.04553 seconds
Time Taken: 0.00116 seconds
Time Before: 0.03991 seconds
Time After: 0.04574 seconds
Time Taken: 0.00583 seconds
Time Before: 0.08176 seconds
Time After: 0.08195 seconds
Time Before: 0.35291 seconds
Time After: 0.35435 seconds
Time Before: 0.37063 seconds
Time After: 0.37081 seconds
Time Before: 0.37332 seconds
Time After: 0.37480 seconds
UPDATE session SET lastactivity = 1785355350, location = '/forums/private.php?do=newpm&explain=1&u=100034' WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.39550 seconds
Time After: 0.39571 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
