Time Before: 0.02363 seconds
Time After: 0.03152 seconds
Time Taken: 0.00789 seconds
Time Before: 0.03162 seconds
Time After: 0.03212 seconds
Time Before: 0.03238 seconds
Time After: 0.03249 seconds
Time Before: 0.03326 seconds
Time After: 0.03578 seconds
Time Taken: 0.00252 seconds
Time Before: 0.03255 seconds
Time After: 0.03994 seconds
Time Taken: 0.00739 seconds
Time Before: 0.04912 seconds
Time After: 0.04944 seconds
Time Before: 0.05171 seconds
Time After: 0.05335 seconds
Time Taken: 0.00164 seconds
Time Before: 0.04848 seconds
Time After: 0.05357 seconds
Time Taken: 0.00508 seconds
Time Before: 0.10002 seconds
Time After: 0.10018 seconds
Time Before: 0.12157 seconds
Time After: 0.12283 seconds
End call of global.php: 0.12494611740112
Time Before: 0.13512 seconds
Time After: 0.13527 seconds
Time Before: 0.13789 seconds
Time After: 0.13977 seconds
Time Taken: 0.00188 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=100039', badlocation = 1
Time Before: 0.16058 seconds
Time After: 0.16083 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
Page generated in 0.15953302383423 seconds with 9 queries, spending 0.0087840557098389 doing MySQL queries and 0.15074896812439 doing PHP things.
