Time Before: 0.02651 seconds
Time After: 0.03197 seconds
Time Taken: 0.00546 seconds
Time Before: 0.03209 seconds
Time After: 0.03257 seconds
Time Before: 0.03287 seconds
Time After: 0.03303 seconds
Time Before: 0.03389 seconds
Time After: 0.03659 seconds
Time Taken: 0.00270 seconds
Time Before: 0.03311 seconds
Time After: 0.04127 seconds
Time Taken: 0.00816 seconds
Time Before: 0.04965 seconds
Time After: 0.04985 seconds
Time Before: 0.05229 seconds
Time After: 0.05350 seconds
Time Before: 0.04894 seconds
Time After: 0.05369 seconds
Time Taken: 0.00475 seconds
Time Before: 0.10198 seconds
Time After: 0.10217 seconds
Time Before: 0.39569 seconds
Time After: 0.39701 seconds
Time Taken: 0.00133 seconds
Time Before: 0.41145 seconds
Time After: 0.41164 seconds
Time Before: 0.41442 seconds
Time After: 0.41599 seconds
Time Taken: 0.00156 seconds
UPDATE session SET lastactivity = 1776685266, location = '/forums/private.php?do=newpm&explain=1&u=100043' WHERE sessionhash = '7f12e449499bf5aa31d8d04cb08a0450'
Time Before: 0.43362 seconds
Time After: 0.43419 seconds
Time Taken: 0.00057 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
