Time Before: 0.01795 seconds
Time After: 0.02185 seconds
Time Taken: 0.00389 seconds
Time Before: 0.02193 seconds
Time After: 0.02233 seconds
Time Before: 0.02255 seconds
Time After: 0.02267 seconds
Time Before: 0.02345 seconds
Time After: 0.02564 seconds
Time Taken: 0.00220 seconds
Time Before: 0.02272 seconds
Time After: 0.03000 seconds
Time Taken: 0.00728 seconds
Time Before: 0.03506 seconds
Time After: 0.03549 seconds
Time Before: 0.03875 seconds
Time After: 0.03991 seconds
Time Taken: 0.00116 seconds
Time Before: 0.03430 seconds
Time After: 0.04014 seconds
Time Taken: 0.00583 seconds
Time Before: 0.07561 seconds
Time After: 0.07578 seconds
Time Before: 0.08962 seconds
Time After: 0.09089 seconds
End call of global.php: 0.092929840087891
Time Before: 0.09916 seconds
Time After: 0.09934 seconds
Time Before: 0.10281 seconds
Time After: 0.10427 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=100046'
Time Before: 0.12803 seconds
Time After: 0.12831 seconds
Page generated in 0.12658596038818 seconds with 9 queries, spending 0.0076563358306885 doing MySQL queries and 0.1189296245575 doing PHP things.
