Time Before: 0.01423 seconds
Time After: 0.01893 seconds
Time Taken: 0.00470 seconds
Time Before: 0.01901 seconds
Time After: 0.01964 seconds
Time Taken: 0.00063 seconds
Time Before: 0.01987 seconds
Time After: 0.02005 seconds
Time Before: 0.02076 seconds
Time After: 0.02270 seconds
Time Taken: 0.00194 seconds
Time Before: 0.02010 seconds
Time After: 0.02741 seconds
Time Taken: 0.00730 seconds
Time Before: 0.03405 seconds
Time After: 0.03449 seconds
Time Before: 0.03741 seconds
Time After: 0.03867 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.03326 seconds
Time After: 0.03892 seconds
Time Taken: 0.00566 seconds
Memory After: 2,261.703 KB
Time Before: 0.05915 seconds
Time After: 0.05931 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.19678 seconds
Time After: 0.19804 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 0.20738 seconds
Time After: 0.20762 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.21062 seconds
Time After: 0.21206 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=100065', badlocation = 1 WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.23260 seconds
Time After: 0.23286 seconds
Memory Before: 4,287.469 KB
Memory After: 4,287.695 KB
