Time Before: 0.02100 seconds
Time After: 0.02720 seconds
Time Taken: 0.00621 seconds
Time Before: 0.02733 seconds
Time After: 0.02776 seconds
Time Before: 0.02797 seconds
Time After: 0.02810 seconds
Time Before: 0.02891 seconds
Time After: 0.03220 seconds
Time Taken: 0.00329 seconds
Time Before: 0.02817 seconds
Time After: 0.03589 seconds
Time Taken: 0.00772 seconds
Time Before: 0.04619 seconds
Time After: 0.04665 seconds
Time Before: 0.04939 seconds
Time After: 0.05055 seconds
Time Taken: 0.00117 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.04557 seconds
Time After: 0.05080 seconds
Time Taken: 0.00523 seconds
Memory After: 2,261.820 KB
Time Before: 0.08055 seconds
Time After: 0.08068 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.10081 seconds
Time After: 0.10202 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
Time Before: 0.11361 seconds
Time After: 0.11376 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.11633 seconds
Time After: 0.11785 seconds
Time Taken: 0.00151 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
UPDATE session SET lastactivity = 1788958652, location = '/forums/private.php?do=newpm&explain=1&u=100066', badlocation = 1 WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.14048 seconds
Time After: 0.14079 seconds
Memory Before: 4,287.836 KB
Memory After: 4,288.047 KB
