Time Before: 0.00932 seconds
Time After: 0.01152 seconds
Time Taken: 0.00221 seconds
Time Before: 0.01160 seconds
Time After: 0.01203 seconds
Time Before: 0.01223 seconds
Time After: 0.01234 seconds
Time Before: 0.01303 seconds
Time After: 0.01565 seconds
Time Taken: 0.00262 seconds
Time Before: 0.01240 seconds
Time After: 0.01952 seconds
Time Taken: 0.00712 seconds
Time Before: 0.02403 seconds
Time After: 0.02437 seconds
Time Before: 0.02672 seconds
Time After: 0.02788 seconds
Time Taken: 0.00116 seconds
Time Before: 0.02334 seconds
Time After: 0.02809 seconds
Time Taken: 0.00475 seconds
Time Before: 0.04559 seconds
Time After: 0.04581 seconds
Time Before: 0.05505 seconds
Time After: 0.05692 seconds
Time Taken: 0.00187 seconds
Time Before: 0.06256 seconds
Time After: 0.06274 seconds
Time Before: 0.06509 seconds
Time After: 0.06653 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=100070', badlocation = 1 WHERE sessionhash = '84d505ff74940a4d05f0ae95a61eba7a'
Time Before: 0.08277 seconds
Time After: 0.08303 seconds
