Time Before: 0.01944 seconds
Time After: 0.02723 seconds
Time Taken: 0.00779 seconds
Time Before: 0.02734 seconds
Time After: 0.02773 seconds
Time Before: 0.02798 seconds
Time After: 0.02813 seconds
Time Before: 0.02891 seconds
Time After: 0.03116 seconds
Time Taken: 0.00225 seconds
Time Before: 0.02819 seconds
Time After: 0.03551 seconds
Time Taken: 0.00732 seconds
Time Before: 0.04646 seconds
Time After: 0.04683 seconds
Time Before: 0.04832 seconds
Time After: 0.04950 seconds
Time Taken: 0.00117 seconds
Time Before: 0.04570 seconds
Time After: 0.04974 seconds
Time Taken: 0.00404 seconds
Time Before: 0.08163 seconds
Time After: 0.08177 seconds
Time Before: 0.09809 seconds
Time After: 0.09932 seconds
End call of global.php: 0.10229301452637
Time Before: 0.10867 seconds
Time After: 0.10884 seconds
Time Before: 0.11155 seconds
Time After: 0.11299 seconds
SET lastactivity = 1776806321, location = '/forums/private.php?do=newpm&explain=1&u=100075', badlocation = 1
Time Before: 0.13209 seconds
Time After: 0.13254 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
Page generated in 0.13084816932678 seconds with 9 queries, spending 0.0077650547027588 doing MySQL queries and 0.12308311462402 doing PHP things.
