Time Before: 0.01044 seconds
Time After: 0.01482 seconds
Time Taken: 0.00438 seconds
Memory Before: 535.055 KB
Memory After: 560.172 KB
Time Before: 0.01495 seconds
Time After: 0.01582 seconds
Time Taken: 0.00087 seconds
Memory Before: 560.109 KB
Memory After: 561.117 KB
Time Before: 0.01620 seconds
Time After: 0.01637 seconds
Memory Before: 561.672 KB
Memory After: 562.195 KB
Time Before: 0.01727 seconds
Time After: 0.01953 seconds
Time Taken: 0.00226 seconds
Memory Before: 564.797 KB
Memory After: 565.719 KB
Time Before: 0.01643 seconds
Time After: 0.02456 seconds
Time Taken: 0.00813 seconds
Memory Before: 561.445 KB
Memory After: 1,642.492 KB
Memory Used: 1,081.047 KB
Time Before: 0.03254 seconds
Time After: 0.03301 seconds
Memory Before: 2,137.445 KB
Memory After: 2,138.063 KB
Time Before: 0.03555 seconds
Time After: 0.03712 seconds
Time Taken: 0.00157 seconds
Memory Before: 2,149.625 KB
Memory After: 2,149.484 KB
Time Before: 0.03176 seconds
Time After: 0.03743 seconds
Time Taken: 0.00567 seconds
Memory Before: 2,129.625 KB
Memory After: 2,262.523 KB
Memory Used: 132.898 KB
Time Before: 0.05575 seconds
Time After: 0.05592 seconds
Memory Before: 2,816.055 KB
Memory After: 2,816.570 KB
Time Before: 0.06909 seconds
Time After: 0.07037 seconds
Memory Before: 2,904.250 KB
Memory After: 2,904.844 KB
Time Before: 0.07780 seconds
Time After: 0.07801 seconds
Memory Before: 3,541.055 KB
Memory After: 3,541.484 KB
Time Before: 0.08087 seconds
Time After: 0.08250 seconds
Time Taken: 0.00164 seconds
Memory Before: 3,822.633 KB
Memory After: 3,824.320 KB
UPDATE session SET lastactivity = 1783091342, location = '/forums/private.php?do=newpm&explain=1&u=100076' WHERE sessionhash = '05bc7c79f91873f78083814ccb7adf41'
Time Before: 0.10105 seconds
Time After: 0.10134 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
