Time Before: 0.02198 seconds
Time After: 0.02838 seconds
Time Taken: 0.00640 seconds
Time Before: 0.02848 seconds
Time After: 0.02898 seconds
Time Before: 0.02923 seconds
Time After: 0.02941 seconds
Time Before: 0.03033 seconds
Time After: 0.03233 seconds
Time Taken: 0.00200 seconds
Time Before: 0.02947 seconds
Time After: 0.03620 seconds
Time Taken: 0.00673 seconds
Time Before: 0.04511 seconds
Time After: 0.04587 seconds
Time Taken: 0.00075 seconds
Time Before: 0.04877 seconds
Time After: 0.04996 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.04435 seconds
Time After: 0.05022 seconds
Time Taken: 0.00587 seconds
Memory After: 2,261.703 KB
Time Before: 0.08674 seconds
Time After: 0.08728 seconds
Time Taken: 0.00054 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.10221 seconds
Time After: 0.10389 seconds
Time Taken: 0.00169 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 0.11237 seconds
Time After: 0.11277 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.11557 seconds
Time After: 0.11703 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=100081', badlocation = 1 WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.13536 seconds
Time After: 0.14169 seconds
Time Taken: 0.00633 seconds
Memory Before: 4,287.469 KB
Memory After: 4,287.695 KB
