Time Before: 0.00174 seconds
Time After: 0.00224 seconds
Time Before: 0.00231 seconds
Time After: 0.00282 seconds
Time Before: 0.00306 seconds
Time After: 0.00321 seconds
Time Before: 0.00402 seconds
Time After: 0.00644 seconds
Time Taken: 0.00242 seconds
Time Before: 0.00330 seconds
Time After: 0.00988 seconds
Time Taken: 0.00658 seconds
Time Before: 0.01168 seconds
Time After: 0.01209 seconds
Time Before: 0.01446 seconds
Time After: 0.01567 seconds
Time Before: 0.01109 seconds
Time After: 0.01584 seconds
Time Taken: 0.00475 seconds
Time Before: 0.02098 seconds
Time After: 0.02119 seconds
Time Before: 0.02298 seconds
Time After: 0.02425 seconds
End call of global.php: 0.025859832763672
Time Before: 0.02702 seconds
Time After: 0.02720 seconds
Time Before: 0.02954 seconds
Time After: 0.03118 seconds
Time Taken: 0.00164 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=100086'
Time Before: 0.04493 seconds
Time After: 0.04526 seconds
Page generated in 0.044018983840942 seconds with 9 queries, spending 0.0083286762237549 doing MySQL queries and 0.035690307617188 doing PHP things.
