Time Before: 0.02575 seconds
Time After: 0.03424 seconds
Time Taken: 0.00849 seconds
Time Before: 0.03435 seconds
Time After: 0.03486 seconds
Time Before: 0.03515 seconds
Time After: 0.03552 seconds
Time Before: 0.03620 seconds
Time After: 0.03814 seconds
Time Taken: 0.00194 seconds
Time Before: 0.03560 seconds
Time After: 0.04352 seconds
Time Taken: 0.00792 seconds
Time Before: 0.05532 seconds
Time After: 0.05568 seconds
Time Before: 0.05754 seconds
Time After: 0.05869 seconds
Time Taken: 0.00115 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.05460 seconds
Time After: 0.05887 seconds
Time Taken: 0.00426 seconds
Memory After: 2,261.820 KB
Time Before: 0.09087 seconds
Time After: 0.09101 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.10978 seconds
Time After: 0.11100 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
Time Before: 0.12182 seconds
Time After: 0.12205 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.12400 seconds
Time After: 0.12544 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
UPDATE session SET lastactivity = 1789058793, location = '/forums/private.php?do=newpm&explain=1&u=100095', badlocation = 1 WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.14439 seconds
Time After: 0.14459 seconds
Memory Before: 4,287.836 KB
Memory After: 4,288.047 KB
