Time Before: 0.01695 seconds
Time After: 0.02318 seconds
Time Taken: 0.00623 seconds
Time Before: 0.02325 seconds
Time After: 0.02373 seconds
Time Before: 0.02394 seconds
Time After: 0.02405 seconds
Time Taken: 0.00010 seconds
Time Before: 0.02484 seconds
Time After: 0.02699 seconds
Time Taken: 0.00215 seconds
Time Before: 0.02412 seconds
Time After: 0.03074 seconds
Time Taken: 0.00662 seconds
Time Before: 0.03613 seconds
Time After: 0.03652 seconds
Time Before: 0.03907 seconds
Time After: 0.04128 seconds
Time Taken: 0.00221 seconds
Time Before: 0.03544 seconds
Time After: 0.04150 seconds
Time Taken: 0.00606 seconds
Time Before: 0.07243 seconds
Time After: 0.07299 seconds
Time Taken: 0.00056 seconds
Time Before: 0.08285 seconds
Time After: 0.08410 seconds
Time Before: 0.09130 seconds
Time After: 0.09149 seconds
Time Before: 0.09453 seconds
Time After: 0.09596 seconds
UPDATE session SET lastactivity = 1776632635, location = '/forums/private.php?do=newpm&explain=1&u=100099' WHERE sessionhash = '0072f2714e5608fd7a8a8d7024a3e041'
Time Before: 0.11353 seconds
Time After: 0.11382 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
