Time Before: 0.01585 seconds
Time After: 0.02166 seconds
Time Taken: 0.00581 seconds
Time Before: 0.02181 seconds
Time After: 0.02238 seconds
Time Taken: 0.00058 seconds
Time Before: 0.02269 seconds
Time After: 0.02287 seconds
Time Before: 0.02371 seconds
Time After: 0.02667 seconds
Time Taken: 0.00296 seconds
Time Before: 0.02295 seconds
Time After: 0.03054 seconds
Time Taken: 0.00759 seconds
Time Before: 0.03707 seconds
Time After: 0.03746 seconds
Time Before: 0.03993 seconds
Time After: 0.04113 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.03641 seconds
Time After: 0.04132 seconds
Time Taken: 0.00491 seconds
Memory After: 2,261.703 KB
Time Before: 0.07000 seconds
Time After: 0.07017 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.08599 seconds
Time After: 0.08728 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 0.09378 seconds
Time After: 0.09395 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.09637 seconds
Time After: 0.09784 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=100102' WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.11429 seconds
Time After: 0.11484 seconds
Time Taken: 0.00055 seconds
Memory Before: 4,287.188 KB
Memory After: 4,287.430 KB
