Time Before: 0.02249 seconds
Time After: 0.03367 seconds
Time Taken: 0.01118 seconds
Time Before: 0.03376 seconds
Time After: 0.03425 seconds
Time Before: 0.03460 seconds
Time After: 0.03476 seconds
Time Before: 0.03570 seconds
Time After: 0.03881 seconds
Time Taken: 0.00311 seconds
Time Before: 0.03484 seconds
Time After: 0.04355 seconds
Time Taken: 0.00871 seconds
Time Before: 0.05369 seconds
Time After: 0.05408 seconds
Time Before: 0.05652 seconds
Time After: 0.05779 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.05303 seconds
Time After: 0.05801 seconds
Time Taken: 0.00498 seconds
Memory After: 2,261.820 KB
Time Before: 0.08586 seconds
Time After: 0.08604 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.10944 seconds
Time After: 0.11072 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
Time Before: 0.12369 seconds
Time After: 0.12387 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.12688 seconds
Time After: 0.12834 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
UPDATE session SET lastactivity = 1789033153, location = '/forums/private.php?do=newpm&explain=1&u=100105' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.14853 seconds
Time After: 0.14880 seconds
Memory Before: 4,287.563 KB
Memory After: 4,287.781 KB
