Time Before: 0.00626 seconds
Time After: 0.01098 seconds
Time Taken: 0.00473 seconds
Time Before: 0.01108 seconds
Time After: 0.01159 seconds
Time Before: 0.01192 seconds
Time After: 0.01207 seconds
Time Before: 0.01275 seconds
Time After: 0.01525 seconds
Time Taken: 0.00249 seconds
Time Before: 0.01213 seconds
Time After: 0.01940 seconds
Time Taken: 0.00727 seconds
Time Before: 0.02393 seconds
Time After: 0.02434 seconds
Time Before: 0.02724 seconds
Time After: 0.02846 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.02327 seconds
Time After: 0.02864 seconds
Time Taken: 0.00537 seconds
Memory After: 2,261.703 KB
Time Before: 0.04017 seconds
Time After: 0.04031 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.04981 seconds
Time After: 0.05131 seconds
Time Taken: 0.00150 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 0.05584 seconds
Time After: 0.05606 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.05826 seconds
Time After: 0.05972 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=100108' WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.07706 seconds
Time After: 0.07733 seconds
Memory Before: 4,287.188 KB
Memory After: 4,287.430 KB
