Time Before: 0.02602 seconds
Time After: 0.03515 seconds
Time Taken: 0.00913 seconds
Time Before: 0.03523 seconds
Time After: 0.03651 seconds
Time Before: 0.03674 seconds
Time After: 0.03690 seconds
Time Before: 0.03758 seconds
Time After: 0.04085 seconds
Time Taken: 0.00326 seconds
Time Before: 0.03695 seconds
Time After: 0.04566 seconds
Time Taken: 0.00871 seconds
Time Before: 0.05529 seconds
Time After: 0.05552 seconds
Time Before: 0.05826 seconds
Time After: 0.05945 seconds
Time Before: 0.05456 seconds
Time After: 0.05966 seconds
Time Taken: 0.00510 seconds
Time Before: 0.10496 seconds
Time After: 0.10509 seconds
Time Before: 0.15750 seconds
Time After: 0.15873 seconds
End call of global.php: 0.16117906570435
Time Before: 0.17220 seconds
Time After: 0.17239 seconds
Time Before: 0.17460 seconds
Time After: 0.17607 seconds
SET lastactivity = 1782850405, location = '/forums/private.php?do=newpm&explain=1&u=100114'
WHERE sessionhash = '708f3049c6f4aeb346a0a4658c824d43'
Time Before: 0.19380 seconds
Time After: 0.19407 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
Page generated in 0.19270992279053 seconds with 9 queries, spending 0.0094180107116699 doing MySQL queries and 0.18329191207886 doing PHP things.
