Time Before: 0.00218 seconds
Time After: 0.00280 seconds
Time Taken: 0.00062 seconds
Time Before: 0.00290 seconds
Time After: 0.00336 seconds
Time Before: 0.00367 seconds
Time After: 0.00380 seconds
Time Before: 0.00472 seconds
Time After: 0.00748 seconds
Time Taken: 0.00276 seconds
Time Before: 0.00388 seconds
Time After: 0.01189 seconds
Time Taken: 0.00801 seconds
Time Before: 0.01384 seconds
Time After: 0.01432 seconds
Time Before: 0.01753 seconds
Time After: 0.01878 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.01308 seconds
Time After: 0.01899 seconds
Time Taken: 0.00591 seconds
Memory After: 2,261.820 KB
Time Before: 0.02414 seconds
Time After: 0.02427 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.02686 seconds
Time After: 0.02821 seconds
Time Taken: 0.00135 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
End call of global.php: 0.030020952224731
Time Before: 0.03166 seconds
Time After: 0.03185 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.03414 seconds
Time After: 0.03562 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
SET lastactivity = 1788973478, location = '/forums/private.php?do=newpm&explain=1&u=100120'
Time Before: 0.04836 seconds
Time After: 0.04860 seconds
Memory Before: 4,287.563 KB
Memory After: 4,287.781 KB
Page generated in 0.047418117523193 seconds with 9 queries, spending 0.0084760189056396 doing MySQL queries and 0.038942098617554 doing PHP things.
