Time Before: 0.00217 seconds
Time After: 0.00283 seconds
Time Taken: 0.00066 seconds
Time Before: 0.00295 seconds
Time After: 0.00344 seconds
Time Before: 0.00372 seconds
Time After: 0.00385 seconds
Time Before: 0.00495 seconds
Time After: 0.00769 seconds
Time Taken: 0.00273 seconds
Time Before: 0.00393 seconds
Time After: 0.01305 seconds
Time Taken: 0.00912 seconds
Time Before: 0.01539 seconds
Time After: 0.01579 seconds
Time Before: 0.01828 seconds
Time After: 0.01948 seconds
Time Before: 0.01460 seconds
Time After: 0.01969 seconds
Time Taken: 0.00508 seconds
Time Before: 0.02494 seconds
Time After: 0.02507 seconds
Time Before: 0.02696 seconds
Time After: 0.02816 seconds
End call of global.php: 0.029964208602905
Time Before: 0.03130 seconds
Time After: 0.03152 seconds
Time Before: 0.03372 seconds
Time After: 0.03519 seconds
SET lastactivity = 1776666091, location = '/forums/private.php?do=newpm&explain=1&u=100129'
Time Before: 0.05348 seconds
Time After: 0.05381 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
Page generated in 0.052521228790283 seconds with 9 queries, spending 0.0083000659942627 doing MySQL queries and 0.044221162796021 doing PHP things.
