Time Before: 0.00965 seconds
Time After: 0.01241 seconds
Time Taken: 0.00276 seconds
Time Before: 0.01255 seconds
Time After: 0.01297 seconds
Time Before: 0.01331 seconds
Time After: 0.01345 seconds
Time Before: 0.01454 seconds
Time After: 0.01722 seconds
Time Taken: 0.00269 seconds
Time Before: 0.01353 seconds
Time After: 0.02117 seconds
Time Taken: 0.00764 seconds
Time Before: 0.02505 seconds
Time After: 0.02549 seconds
Time Before: 0.02896 seconds
Time After: 0.03016 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.02419 seconds
Time After: 0.03037 seconds
Time Taken: 0.00618 seconds
Memory After: 2,261.820 KB
Time Before: 0.04696 seconds
Time After: 0.04709 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.05540 seconds
Time After: 0.05667 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
End call of global.php: 0.058523893356323
Time Before: 0.06212 seconds
Time After: 0.06227 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.06456 seconds
Time After: 0.06599 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
SET lastactivity = 1788989069, location = '/forums/private.php?do=newpm&explain=1&u=100130'
Time Before: 0.08146 seconds
Time After: 0.08190 seconds
Memory Before: 4,287.563 KB
Memory After: 4,287.781 KB
Page generated in 0.080371856689453 seconds with 9 queries, spending 0.0083086490631104 doing MySQL queries and 0.072063207626343 doing PHP things.
