Time Before: 0.02624 seconds
Time After: 0.03922 seconds
Time Taken: 0.01299 seconds
Time Before: 0.03930 seconds
Time After: 0.04040 seconds
Time Taken: 0.00110 seconds
Time Before: 0.04062 seconds
Time After: 0.04075 seconds
Time Before: 0.04193 seconds
Time After: 0.04490 seconds
Time Taken: 0.00297 seconds
Time Before: 0.04083 seconds
Time After: 0.04977 seconds
Time Taken: 0.00893 seconds
Time Before: 0.06100 seconds
Time After: 0.06139 seconds
Time Before: 0.06426 seconds
Time After: 0.06551 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.05986 seconds
Time After: 0.06574 seconds
Time Taken: 0.00587 seconds
Memory After: 2,261.703 KB
Time Before: 0.09187 seconds
Time After: 0.09203 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.11016 seconds
Time After: 0.11139 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 0.12007 seconds
Time After: 0.12022 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.12283 seconds
Time After: 0.12423 seconds
Time Taken: 0.00139 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=100136' WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.14305 seconds
Time After: 0.14337 seconds
Memory Before: 4,287.188 KB
Memory After: 4,287.430 KB
