Time Before: 0.00155 seconds
Time After: 0.00197 seconds
Time Before: 0.00204 seconds
Time After: 0.00240 seconds
Time Before: 0.00259 seconds
Time After: 0.00276 seconds
Time Before: 0.00348 seconds
Time After: 0.00563 seconds
Time Taken: 0.00215 seconds
Time Before: 0.00281 seconds
Time After: 0.00971 seconds
Time Taken: 0.00690 seconds
Time Before: 0.01157 seconds
Time After: 0.01199 seconds
Time Before: 0.01372 seconds
Time After: 0.01491 seconds
Time Before: 0.01095 seconds
Time After: 0.01509 seconds
Time Taken: 0.00414 seconds
Time Before: 0.02105 seconds
Time After: 0.02117 seconds
Time Before: 0.02320 seconds
Time After: 0.02447 seconds
End call of global.php: 0.026198863983154
Time Before: 0.02756 seconds
Time After: 0.02771 seconds
Time Before: 0.02975 seconds
Time After: 0.03119 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=100140'
Time Before: 0.04971 seconds
Time After: 0.04999 seconds
Page generated in 0.048776865005493 seconds with 9 queries, spending 0.0075504779815674 doing MySQL queries and 0.041226387023926 doing PHP things.
