Time Before: 0.00927 seconds
Time After: 0.01279 seconds
Time Taken: 0.00352 seconds
Time Before: 0.01286 seconds
Time After: 0.01330 seconds
Time Before: 0.01355 seconds
Time After: 0.01373 seconds
Time Before: 0.01442 seconds
Time After: 0.01773 seconds
Time Taken: 0.00331 seconds
Time Before: 0.01378 seconds
Time After: 0.02244 seconds
Time Taken: 0.00866 seconds
Time Before: 0.02809 seconds
Time After: 0.02843 seconds
Time Before: 0.03102 seconds
Time After: 0.03297 seconds
Time Taken: 0.00195 seconds
Time Before: 0.02749 seconds
Time After: 0.03318 seconds
Time Taken: 0.00569 seconds
Time Before: 0.04540 seconds
Time After: 0.04557 seconds
Time Before: 0.05615 seconds
Time After: 0.05740 seconds
End call of global.php: 0.059525966644287
Time Before: 0.06416 seconds
Time After: 0.06431 seconds
Time Before: 0.06710 seconds
Time After: 0.06862 seconds
Time Taken: 0.00153 seconds
SET lastactivity = 1789026062, location = '/forums/private.php?do=newpm&explain=1&u=100146', badlocation = 1
Time Before: 0.08785 seconds
Time After: 0.08812 seconds
Page generated in 0.086529970169067 seconds with 9 queries, spending 0.0095870494842529 doing MySQL queries and 0.076942920684814 doing PHP things.
