Time Before: 0.02499 seconds
Time After: 0.03214 seconds
Time Taken: 0.00715 seconds
Time Before: 0.03224 seconds
Time After: 0.03270 seconds
Time Before: 0.03296 seconds
Time After: 0.03313 seconds
Time Before: 0.03398 seconds
Time After: 0.03657 seconds
Time Taken: 0.00258 seconds
Time Before: 0.03321 seconds
Time After: 0.04092 seconds
Time Taken: 0.00771 seconds
Time Before: 0.05185 seconds
Time After: 0.05223 seconds
Time Before: 0.05368 seconds
Time After: 0.05486 seconds
Time Taken: 0.00118 seconds
Time Before: 0.05122 seconds
Time After: 0.05507 seconds
Time Taken: 0.00385 seconds
Time Before: 0.09926 seconds
Time After: 0.09942 seconds
Time Before: 0.12352 seconds
Time After: 0.12487 seconds
Time Taken: 0.00134 seconds
Time Before: 0.13525 seconds
Time After: 0.13544 seconds
Time Before: 0.13872 seconds
Time After: 0.14014 seconds
UPDATE session SET lastactivity = 1785429601, location = '/forums/private.php?do=newpm&explain=1&u=100162' WHERE sessionhash = 'dd14cf6af34df6bab38ac9fb3783395f'
Time Before: 0.16616 seconds
Time After: 0.16647 seconds
Memory Before: 4,289.063 KB
Memory After: 4,289.289 KB
