Time Before: 0.00154 seconds
Time After: 0.00209 seconds
Time Taken: 0.00056 seconds
Time Before: 0.00216 seconds
Time After: 0.00268 seconds
Time Before: 0.00289 seconds
Time After: 0.00306 seconds
Time Before: 0.00372 seconds
Time After: 0.00635 seconds
Time Taken: 0.00262 seconds
Time Before: 0.00311 seconds
Time After: 0.00985 seconds
Time Taken: 0.00674 seconds
Time Before: 0.01171 seconds
Time After: 0.01194 seconds
Time Before: 0.01445 seconds
Time After: 0.01563 seconds
Time Taken: 0.00117 seconds
Time Before: 0.01107 seconds
Time After: 0.01586 seconds
Time Taken: 0.00479 seconds
Time Before: 0.02146 seconds
Time After: 0.02164 seconds
Time Before: 0.02343 seconds
Time After: 0.02466 seconds
Time Before: 0.02846 seconds
Time After: 0.02876 seconds
Time Before: 0.03169 seconds
Time After: 0.03317 seconds
UPDATE session SET lastactivity = 1776644810, location = '/forums/private.php?do=newpm&explain=1&u=100176', badlocation = 1 WHERE sessionhash = '0072f2714e5608fd7a8a8d7024a3e041'
Time Before: 0.05160 seconds
Time After: 0.05192 seconds
