Time Before: 0.00323 seconds
Time After: 0.00412 seconds
Time Taken: 0.00089 seconds
Time Before: 0.00423 seconds
Time After: 0.00466 seconds
Time Before: 0.00494 seconds
Time After: 0.00509 seconds
Time Before: 0.00601 seconds
Time After: 0.00823 seconds
Time Taken: 0.00222 seconds
Time Before: 0.00518 seconds
Time After: 0.01242 seconds
Time Taken: 0.00724 seconds
Time Before: 0.01555 seconds
Time After: 0.01601 seconds
Time Before: 0.01881 seconds
Time After: 0.02003 seconds
Time Before: 0.01466 seconds
Time After: 0.02030 seconds
Time Taken: 0.00564 seconds
Time Before: 0.02884 seconds
Time After: 0.02903 seconds
Time Before: 0.03154 seconds
Time After: 0.03277 seconds
Time Before: 0.03586 seconds
Time After: 0.03601 seconds
Time Before: 0.03853 seconds
Time After: 0.03998 seconds
UPDATE session SET lastactivity = 1789033224, location = '/forums/private.php?do=newpm&explain=1&u=100187' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.05564 seconds
Time After: 0.05595 seconds
