Time Before: 0.00257 seconds
Time After: 0.00309 seconds
Time Before: 0.00317 seconds
Time After: 0.00357 seconds
Time Before: 0.00377 seconds
Time After: 0.00390 seconds
Time Before: 0.00455 seconds
Time After: 0.00712 seconds
Time Taken: 0.00257 seconds
Time Before: 0.00394 seconds
Time After: 0.01141 seconds
Time Taken: 0.00747 seconds
Time Before: 0.01371 seconds
Time After: 0.01428 seconds
Time Taken: 0.00057 seconds
Time Before: 0.01642 seconds
Time After: 0.01764 seconds
Time Before: 0.01275 seconds
Time After: 0.01782 seconds
Time Taken: 0.00507 seconds
Time Before: 0.02317 seconds
Time After: 0.02335 seconds
Time Before: 0.02682 seconds
Time After: 0.02932 seconds
Time Taken: 0.00250 seconds
Time Before: 0.03358 seconds
Time After: 0.03373 seconds
Time Before: 0.03757 seconds
Time After: 0.04050 seconds
Time Taken: 0.00292 seconds
UPDATE session SET lastactivity = 1789068001, location = '/forums/private.php?do=newpm&explain=1&u=100188', badlocation = 1 WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.06018 seconds
Time After: 0.06044 seconds
Memory Before: 4,912.320 KB
Memory After: 4,912.531 KB
