Time Before: 0.00943 seconds
Time After: 0.01216 seconds
Time Taken: 0.00272 seconds
Memory Before: 1,245.656 KB
Memory After: 1,272.438 KB
Memory Used: 26.781 KB
Time Before: 0.01226 seconds
Time After: 0.01263 seconds
Memory Before: 1,272.398 KB
Memory After: 1,273.375 KB
Time Before: 0.01283 seconds
Time After: 0.01296 seconds
Memory Before: 1,274.016 KB
Memory After: 1,274.539 KB
Time Before: 0.01367 seconds
Time After: 0.01591 seconds
Time Taken: 0.00224 seconds
Memory Before: 1,277.406 KB
Memory After: 1,278.328 KB
Time Before: 0.01302 seconds
Time After: 0.02029 seconds
Time Taken: 0.00727 seconds
Memory Before: 1,273.820 KB
Memory After: 2,355.039 KB
Memory Used: 1,081.219 KB
Time Before: 0.02428 seconds
Time After: 0.02448 seconds
Memory Before: 2,895.203 KB
Memory After: 2,895.820 KB
Time Before: 0.02574 seconds
Time After: 0.02698 seconds
Memory Before: 2,907.648 KB
Memory After: 2,907.508 KB
Time Before: 0.02356 seconds
Time After: 0.02722 seconds
Time Taken: 0.00366 seconds
Memory Before: 2,887.930 KB
Memory After: 3,020.563 KB
Memory Used: 132.633 KB
Time Before: 0.05657 seconds
Time After: 0.05671 seconds
Memory Before: 3,655.094 KB
Memory After: 3,655.609 KB
Time Before: 0.09671 seconds
Time After: 0.09798 seconds
Memory Before: 4,132.773 KB
Memory After: 4,133.367 KB
Time Before: 0.12042 seconds
Time After: 0.12059 seconds
Memory Before: 5,196.969 KB
Memory After: 5,325.313 KB
Time Before: 0.12533 seconds
Time After: 0.12677 seconds
Memory Before: 5,480.648 KB
Memory After: 5,610.250 KB
UPDATE session SET lastactivity = 1773272027, location = '/forums/private.php?do=newpm&explain=1&u=100194' WHERE sessionhash = '4737b6efab9faed20c53299b3b330814'
Time Before: 0.15137 seconds
Time After: 0.15165 seconds
Memory Before: 6,005.359 KB
Memory After: 6,005.586 KB
