Time Before: 0.00195 seconds
Time After: 0.00238 seconds
Time Before: 0.00246 seconds
Time After: 0.00290 seconds
Time Before: 0.00311 seconds
Time After: 0.00323 seconds
Time Before: 0.00385 seconds
Time After: 0.00608 seconds
Time Taken: 0.00223 seconds
Time Before: 0.00328 seconds
Time After: 0.00950 seconds
Time Taken: 0.00622 seconds
Time Before: 0.01120 seconds
Time After: 0.01154 seconds
Time Before: 0.01399 seconds
Time After: 0.01548 seconds
Time Before: 0.01068 seconds
Time After: 0.01565 seconds
Time Taken: 0.00497 seconds
Time Before: 0.02069 seconds
Time After: 0.02082 seconds
Time Before: 0.02267 seconds
Time After: 0.02387 seconds
Time Before: 0.02681 seconds
Time After: 0.02698 seconds
Time Before: 0.02896 seconds
Time After: 0.03036 seconds
Time Taken: 0.00140 seconds
UPDATE session SET lastactivity = 1788870336, location = '/forums/private.php?do=newpm&explain=1&u=100201', badlocation = 1 WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.04290 seconds
Time After: 0.04317 seconds
