Time Before: 0.01566 seconds
Time After: 0.02196 seconds
Time Taken: 0.00629 seconds
Time Before: 0.02206 seconds
Time After: 0.02259 seconds
Time Taken: 0.00054 seconds
Time Before: 0.02287 seconds
Time After: 0.02303 seconds
Time Before: 0.02384 seconds
Time After: 0.02674 seconds
Time Taken: 0.00290 seconds
Time Before: 0.02311 seconds
Time After: 0.03223 seconds
Time Taken: 0.00912 seconds
Time Before: 0.04211 seconds
Time After: 0.04248 seconds
Time Before: 0.04386 seconds
Time After: 0.04514 seconds
Time Before: 0.04144 seconds
Time After: 0.04539 seconds
Time Taken: 0.00395 seconds
Time Before: 0.07121 seconds
Time After: 0.07144 seconds
Time Before: 0.08299 seconds
Time After: 0.08426 seconds
Time Before: 0.09099 seconds
Time After: 0.09116 seconds
Time Before: 0.09370 seconds
Time After: 0.09516 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=100202', badlocation = 1 WHERE sessionhash = '05bc7c79f91873f78083814ccb7adf41'
Time Before: 0.11205 seconds
Time After: 0.11233 seconds
Memory Before: 4,911.867 KB
Memory After: 4,912.094 KB
