Time Before: 0.00827 seconds
Time After: 0.01043 seconds
Time Taken: 0.00216 seconds
Time Before: 0.01054 seconds
Time After: 0.01097 seconds
Time Before: 0.01121 seconds
Time After: 0.01136 seconds
Time Before: 0.01218 seconds
Time After: 0.01449 seconds
Time Taken: 0.00232 seconds
Time Before: 0.01143 seconds
Time After: 0.01903 seconds
Time Taken: 0.00760 seconds
Time Before: 0.02360 seconds
Time After: 0.02399 seconds
Time Before: 0.02699 seconds
Time After: 0.02821 seconds
Time Before: 0.02275 seconds
Time After: 0.02852 seconds
Time Taken: 0.00576 seconds
Time Before: 0.04411 seconds
Time After: 0.04426 seconds
Time Before: 0.04995 seconds
Time After: 0.05119 seconds
End call of global.php: 0.053428888320923
Time Before: 0.05719 seconds
Time After: 0.05736 seconds
Time Before: 0.05979 seconds
Time After: 0.06123 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=100205', badlocation = 1
Time Before: 0.07985 seconds
Time After: 0.08009 seconds
Page generated in 0.078629970550537 seconds with 9 queries, spending 0.0077419281005859 doing MySQL queries and 0.070888042449951 doing PHP things.
