Time Before: 0.00177 seconds
Time After: 0.00252 seconds
Time Taken: 0.00075 seconds
Memory Before: 1,159.359 KB
Memory After: 1,184.477 KB
Time Before: 0.00261 seconds
Time After: 0.00315 seconds
Time Taken: 0.00053 seconds
Memory Before: 1,184.414 KB
Memory After: 1,185.422 KB
Time Before: 0.00345 seconds
Time After: 0.00358 seconds
Memory Before: 1,186.008 KB
Memory After: 1,186.531 KB
Time Before: 0.00445 seconds
Time After: 0.00817 seconds
Time Taken: 0.00372 seconds
Memory Before: 1,189.133 KB
Memory After: 1,190.055 KB
Time Before: 0.00363 seconds
Time After: 0.01154 seconds
Time Taken: 0.00791 seconds
Memory Before: 1,185.750 KB
Memory After: 2,266.781 KB
Time Before: 0.01353 seconds
Time After: 0.01401 seconds
Memory Before: 2,759.484 KB
Memory After: 2,760.102 KB
Time Before: 0.01684 seconds
Time After: 0.01965 seconds
Time Taken: 0.00281 seconds
Memory Before: 2,771.656 KB
Memory After: 2,771.516 KB
Time Before: 0.01291 seconds
Time After: 0.01986 seconds
Time Taken: 0.00695 seconds
Memory Before: 2,751.625 KB
Memory After: 2,884.547 KB
Time Before: 0.02487 seconds
Time After: 0.02504 seconds
Memory Before: 3,437.688 KB
Memory After: 3,438.203 KB
Time Before: 0.02718 seconds
Time After: 0.02920 seconds
Time Taken: 0.00202 seconds
Memory Before: 3,525.500 KB
Memory After: 3,526.094 KB
Time Before: 0.03337 seconds
Time After: 0.03371 seconds
Memory Before: 4,163.391 KB
Memory After: 4,163.820 KB
Time Before: 0.03579 seconds
Time After: 0.03725 seconds
Memory Before: 4,444.953 KB
Memory After: 4,446.641 KB
UPDATE session SET lastactivity = 1788899054, location = '/forums/private.php?do=newpm&explain=1&u=100211' WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.05323 seconds
Time After: 0.05349 seconds
Memory Before: 4,918.805 KB
Memory After: 4,919.031 KB
