Time Before: 0.01032 seconds
Time After: 0.01307 seconds
Time Taken: 0.00275 seconds
Time Before: 0.01317 seconds
Time After: 0.01367 seconds
Time Before: 0.01393 seconds
Time After: 0.01406 seconds
Time Before: 0.01475 seconds
Time After: 0.01739 seconds
Time Taken: 0.00263 seconds
Time Before: 0.01413 seconds
Time After: 0.02270 seconds
Time Taken: 0.00857 seconds
Time Before: 0.02834 seconds
Time After: 0.02876 seconds
Time Before: 0.03141 seconds
Time After: 0.03261 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.02761 seconds
Time After: 0.03282 seconds
Time Taken: 0.00521 seconds
Memory After: 2,261.703 KB
Time Before: 0.05325 seconds
Time After: 0.05343 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.06311 seconds
Time After: 0.06437 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
End call of global.php: 0.066992998123169
Time Before: 0.06991 seconds
Time After: 0.07006 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.07220 seconds
Time After: 0.07365 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=100223'
Time Before: 0.08954 seconds
Time After: 0.09003 seconds
Memory Before: 4,287.188 KB
Memory After: 4,287.430 KB
Page generated in 0.088449954986572 seconds with 9 queries, spending 0.0084061622619629 doing MySQL queries and 0.080043792724609 doing PHP things.
