Time Before: 0.00223 seconds
Time After: 0.00324 seconds
Time Taken: 0.00102 seconds
Time Before: 0.00334 seconds
Time After: 0.00381 seconds
Time Before: 0.00404 seconds
Time After: 0.00417 seconds
Time Before: 0.00500 seconds
Time After: 0.00748 seconds
Time Taken: 0.00248 seconds
Time Before: 0.00422 seconds
Time After: 0.01204 seconds
Time Taken: 0.00782 seconds
Time Before: 0.01385 seconds
Time After: 0.01427 seconds
Time Before: 0.01698 seconds
Time After: 0.01832 seconds
Time Taken: 0.00134 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.01323 seconds
Time After: 0.01853 seconds
Time Taken: 0.00530 seconds
Memory After: 2,261.703 KB
Time Before: 0.02555 seconds
Time After: 0.02573 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.02817 seconds
Time After: 0.02969 seconds
Time Taken: 0.00152 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
End call of global.php: 0.031999111175537
Time Before: 0.03384 seconds
Time After: 0.03400 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.03596 seconds
Time After: 0.03744 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=100237'
Time Before: 0.05341 seconds
Time After: 0.05367 seconds
Memory Before: 4,287.188 KB
Memory After: 4,287.430 KB
Page generated in 0.052446126937866 seconds with 9 queries, spending 0.0084402561187744 doing MySQL queries and 0.044005870819092 doing PHP things.
