Time Before: 0.00148 seconds
Time After: 0.00203 seconds
Time Taken: 0.00055 seconds
Time Before: 0.00210 seconds
Time After: 0.00261 seconds
Time Before: 0.00284 seconds
Time After: 0.00294 seconds
Time Taken: 0.00010 seconds
Time Before: 0.00361 seconds
Time After: 0.00624 seconds
Time Taken: 0.00263 seconds
Time Before: 0.00299 seconds
Time After: 0.01078 seconds
Time Taken: 0.00779 seconds
Time Before: 0.01330 seconds
Time After: 0.01353 seconds
Time Before: 0.01510 seconds
Time After: 0.01637 seconds
Time Before: 0.01249 seconds
Time After: 0.01663 seconds
Time Taken: 0.00414 seconds
Time Before: 0.02164 seconds
Time After: 0.02178 seconds
Time Before: 0.02411 seconds
Time After: 0.02536 seconds
Time Before: 0.02849 seconds
Time After: 0.02866 seconds
Time Before: 0.03066 seconds
Time After: 0.03253 seconds
Time Taken: 0.00188 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=100254', badlocation = 1 WHERE sessionhash = 'f9921609250f226198462d57df303337'
Time Before: 0.04668 seconds
Time After: 0.04712 seconds
Memory Before: 4,911.867 KB
Memory After: 4,912.094 KB
