Time Before: 0.00140 seconds
Time After: 0.00192 seconds
Time Before: 0.00199 seconds
Time After: 0.00268 seconds
Time Taken: 0.00069 seconds
Time Before: 0.00298 seconds
Time After: 0.00314 seconds
Time Before: 0.00389 seconds
Time After: 0.00854 seconds
Time Taken: 0.00464 seconds
Time Before: 0.00320 seconds
Time After: 0.01304 seconds
Time Taken: 0.00984 seconds
Time Before: 0.01489 seconds
Time After: 0.01531 seconds
Time Before: 0.01809 seconds
Time After: 0.01982 seconds
Time Taken: 0.00172 seconds
Time Before: 0.01423 seconds
Time After: 0.02005 seconds
Time Taken: 0.00583 seconds
Time Before: 0.02648 seconds
Time After: 0.02669 seconds
Time Before: 0.02903 seconds
Time After: 0.03035 seconds
Time Taken: 0.00132 seconds
Time Before: 0.03470 seconds
Time After: 0.03495 seconds
Time Before: 0.03748 seconds
Time After: 0.03893 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=100256' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.05332 seconds
Time After: 0.06023 seconds
Time Taken: 0.00691 seconds
