Time Before: 0.00301 seconds
Time After: 0.00398 seconds
Time Taken: 0.00097 seconds
Time Before: 0.00408 seconds
Time After: 0.00446 seconds
Time Before: 0.00471 seconds
Time After: 0.00520 seconds
Time Before: 0.00614 seconds
Time After: 0.00859 seconds
Time Taken: 0.00245 seconds
Time Before: 0.00527 seconds
Time After: 0.01233 seconds
Time Taken: 0.00705 seconds
Time Before: 0.01471 seconds
Time After: 0.01503 seconds
Time Before: 0.01738 seconds
Time After: 0.01858 seconds
Time Before: 0.01417 seconds
Time After: 0.01877 seconds
Time Taken: 0.00460 seconds
Time Before: 0.02673 seconds
Time After: 0.02686 seconds
Time Before: 0.03025 seconds
Time After: 0.03149 seconds
End call of global.php: 0.033166170120239
Time Before: 0.03472 seconds
Time After: 0.03485 seconds
Time Before: 0.03680 seconds
Time After: 0.03828 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=100257'
Time Before: 0.05291 seconds
Time After: 0.05323 seconds
Memory Before: 4,911.586 KB
Memory After: 4,911.828 KB
Page generated in 0.051947116851807 seconds with 9 queries, spending 0.0081498622894287 doing MySQL queries and 0.043797254562378 doing PHP things.
