Time Before: 0.00793 seconds
Time After: 0.00989 seconds
Time Taken: 0.00195 seconds
Time Before: 0.01000 seconds
Time After: 0.01048 seconds
Time Before: 0.01075 seconds
Time After: 0.01089 seconds
Time Before: 0.01179 seconds
Time After: 0.01400 seconds
Time Taken: 0.00221 seconds
Time Before: 0.01097 seconds
Time After: 0.01849 seconds
Time Taken: 0.00752 seconds
Time Before: 0.02257 seconds
Time After: 0.02309 seconds
Time Before: 0.02659 seconds
Time After: 0.02800 seconds
Time Before: 0.02183 seconds
Time After: 0.02828 seconds
Time Taken: 0.00645 seconds
Time Before: 0.04071 seconds
Time After: 0.04086 seconds
Time Before: 0.04656 seconds
Time After: 0.04782 seconds
End call of global.php: 0.049982070922852
Time Before: 0.05390 seconds
Time After: 0.05405 seconds
Time Before: 0.05639 seconds
Time After: 0.05784 seconds
SET lastactivity = 1776734233, location = '/forums/private.php?do=newpm&explain=1&u=100265'
Time Before: 0.07153 seconds
Time After: 0.07183 seconds
Page generated in 0.070429086685181 seconds with 9 queries, spending 0.0080740451812744 doing MySQL queries and 0.062355041503906 doing PHP things.
