Time Before: 0.00134 seconds
Time After: 0.00189 seconds
Time Taken: 0.00055 seconds
Memory Before: 1,159.359 KB
Memory After: 1,184.477 KB
Time Before: 0.00196 seconds
Time After: 0.00251 seconds
Memory Before: 1,184.414 KB
Memory After: 1,185.422 KB
Time Before: 0.00276 seconds
Time After: 0.00289 seconds
Memory Before: 1,186.008 KB
Memory After: 1,186.531 KB
Time Before: 0.00354 seconds
Time After: 0.00576 seconds
Time Taken: 0.00222 seconds
Memory Before: 1,189.133 KB
Memory After: 1,190.055 KB
Time Before: 0.00294 seconds
Time After: 0.00926 seconds
Time Taken: 0.00632 seconds
Memory Before: 1,185.750 KB
Memory After: 2,266.766 KB
Time Before: 0.01136 seconds
Time After: 0.01179 seconds
Memory Before: 2,759.469 KB
Memory After: 2,760.086 KB
Time Before: 0.01315 seconds
Time After: 0.01437 seconds
Memory Before: 2,771.641 KB
Memory After: 2,771.500 KB
Time Before: 0.01073 seconds
Time After: 0.01463 seconds
Time Taken: 0.00390 seconds
Memory Before: 2,751.609 KB
Memory After: 2,884.531 KB
Time Before: 0.02238 seconds
Time After: 0.02264 seconds
Memory Before: 3,437.641 KB
Memory After: 3,438.156 KB
Time Before: 0.02629 seconds
Time After: 0.02759 seconds
Memory Before: 3,525.438 KB
Memory After: 3,526.031 KB
Time Before: 0.03220 seconds
Time After: 0.03243 seconds
Memory Before: 4,163.305 KB
Memory After: 4,163.734 KB
Time Before: 0.03599 seconds
Time After: 0.03750 seconds
Time Taken: 0.00151 seconds
Memory Before: 4,444.867 KB
Memory After: 4,446.555 KB
UPDATE session SET lastactivity = 1785341921, location = '/forums/private.php?do=newpm&explain=1&u=10028' WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.05283 seconds
Time After: 0.05313 seconds
Memory Before: 4,918.703 KB
Memory After: 4,918.930 KB
