Time Before: 0.00146 seconds
Time After: 0.00199 seconds
Time Before: 0.00206 seconds
Time After: 0.00245 seconds
Time Before: 0.00371 seconds
Time After: 0.00420 seconds
Time Before: 0.00531 seconds
Time After: 0.00788 seconds
Time Taken: 0.00257 seconds
Time Before: 0.00425 seconds
Time After: 0.01136 seconds
Time Taken: 0.00711 seconds
Time Before: 0.01349 seconds
Time After: 0.01401 seconds
Time Before: 0.01663 seconds
Time After: 0.01789 seconds
Time Before: 0.01287 seconds
Time After: 0.01808 seconds
Time Taken: 0.00520 seconds
Time Before: 0.02330 seconds
Time After: 0.02351 seconds
Time Before: 0.02591 seconds
Time After: 0.02717 seconds
Time Before: 0.03018 seconds
Time After: 0.03034 seconds
Time Before: 0.03241 seconds
Time After: 0.03390 seconds
Time Taken: 0.00150 seconds
UPDATE session SET lastactivity = 1788984754, location = '/forums/private.php?do=newpm&explain=1&u=100288' WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.04657 seconds
Time After: 0.05092 seconds
Time Taken: 0.00435 seconds
