Time Before: 0.00134 seconds
Time After: 0.00180 seconds
Time Before: 0.00187 seconds
Time After: 0.00243 seconds
Time Taken: 0.00056 seconds
Time Before: 0.00272 seconds
Time After: 0.00287 seconds
Time Before: 0.00373 seconds
Time After: 0.00653 seconds
Time Taken: 0.00280 seconds
Time Before: 0.00295 seconds
Time After: 0.01195 seconds
Time Taken: 0.00900 seconds
Time Before: 0.01411 seconds
Time After: 0.01449 seconds
Time Before: 0.01719 seconds
Time After: 0.01842 seconds
Time Before: 0.01339 seconds
Time After: 0.01862 seconds
Time Taken: 0.00523 seconds
Time Before: 0.02537 seconds
Time After: 0.02561 seconds
Time Before: 0.02749 seconds
Time After: 0.02882 seconds
Time Taken: 0.00132 seconds
End call of global.php: 0.031176090240479
Time Before: 0.03251 seconds
Time After: 0.03268 seconds
Time Before: 0.03541 seconds
Time After: 0.03690 seconds
SET lastactivity = 1785351470, location = '/forums/private.php?do=newpm&explain=1&u=100291'
Time Before: 0.05019 seconds
Time After: 0.05046 seconds
Page generated in 0.049211978912354 seconds with 9 queries, spending 0.0086159706115723 doing MySQL queries and 0.040596008300781 doing PHP things.
