Time Before: 0.00133 seconds
Time After: 0.00190 seconds
Time Taken: 0.00057 seconds
Memory Before: 1,159.359 KB
Memory After: 1,184.477 KB
Time Before: 0.00197 seconds
Time After: 0.00254 seconds
Memory Before: 1,184.414 KB
Memory After: 1,185.422 KB
Time Before: 0.00277 seconds
Time After: 0.00290 seconds
Memory Before: 1,186.008 KB
Memory After: 1,186.531 KB
Time Before: 0.00359 seconds
Time After: 0.00683 seconds
Time Taken: 0.00324 seconds
Memory Before: 1,189.133 KB
Memory After: 1,190.055 KB
Time Before: 0.00294 seconds
Time After: 0.01025 seconds
Time Taken: 0.00730 seconds
Memory Before: 1,185.750 KB
Memory After: 2,266.781 KB
Time Before: 0.01209 seconds
Time After: 0.01248 seconds
Memory Before: 2,759.484 KB
Memory After: 2,760.102 KB
Time Before: 0.01489 seconds
Time After: 0.01615 seconds
Memory Before: 2,771.656 KB
Memory After: 2,771.516 KB
Time Before: 0.01152 seconds
Time After: 0.01632 seconds
Time Taken: 0.00480 seconds
Memory Before: 2,751.625 KB
Memory After: 2,884.547 KB
Time Before: 0.02123 seconds
Time After: 0.02139 seconds
Memory Before: 3,437.688 KB
Memory After: 3,438.203 KB
Time Before: 0.02339 seconds
Time After: 0.02463 seconds
Memory Before: 3,525.500 KB
Memory After: 3,526.094 KB
Time Before: 0.02752 seconds
Time After: 0.02765 seconds
Memory Before: 4,163.391 KB
Memory After: 4,163.820 KB
Time Before: 0.02963 seconds
Time After: 0.03108 seconds
Memory Before: 4,444.953 KB
Memory After: 4,446.641 KB
UPDATE session SET lastactivity = 1788900283, location = '/forums/private.php?do=newpm&explain=1&u=100306' WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.04351 seconds
Time After: 0.04382 seconds
Memory Before: 4,918.805 KB
Memory After: 4,919.031 KB
