Time Before: 0.00180 seconds
Time After: 0.00259 seconds
Time Taken: 0.00080 seconds
Time Before: 0.00266 seconds
Time After: 0.00309 seconds
Time Before: 0.00333 seconds
Time After: 0.00345 seconds
Time Before: 0.00407 seconds
Time After: 0.00704 seconds
Time Taken: 0.00297 seconds
Time Before: 0.00350 seconds
Time After: 0.01043 seconds
Time Taken: 0.00693 seconds
Time Before: 0.01220 seconds
Time After: 0.01256 seconds
Time Before: 0.01504 seconds
Time After: 0.01640 seconds
Time Taken: 0.00136 seconds
Time Before: 0.01162 seconds
Time After: 0.01665 seconds
Time Taken: 0.00503 seconds
Time Before: 0.02272 seconds
Time After: 0.02290 seconds
Time Before: 0.02471 seconds
Time After: 0.02593 seconds
Time Before: 0.02869 seconds
Time After: 0.02881 seconds
Time Before: 0.03068 seconds
Time After: 0.03209 seconds
UPDATE session SET lastactivity = 1789140287, location = '/forums/private.php?do=newpm&explain=1&u=100312' WHERE sessionhash = '2e9a27470c1bd6d04caedfc611bd3cf4'
Time Before: 0.04524 seconds
Time After: 0.04559 seconds
