Time Before: 0.01059 seconds
Time After: 0.01537 seconds
Time Taken: 0.00478 seconds
Time Before: 0.01548 seconds
Time After: 0.01600 seconds
Time Before: 0.01630 seconds
Time After: 0.01644 seconds
Time Before: 0.01724 seconds
Time After: 0.01968 seconds
Time Taken: 0.00243 seconds
Time Before: 0.01650 seconds
Time After: 0.02381 seconds
Time Taken: 0.00731 seconds
Time Before: 0.02945 seconds
Time After: 0.02983 seconds
Time Before: 0.03236 seconds
Time After: 0.03356 seconds
Time Before: 0.02873 seconds
Time After: 0.03380 seconds
Time Taken: 0.00507 seconds
Time Before: 0.05734 seconds
Time After: 0.05749 seconds
Time Before: 0.06721 seconds
Time After: 0.06845 seconds
Time Before: 0.07378 seconds
Time After: 0.07399 seconds
Time Before: 0.07648 seconds
Time After: 0.07792 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=100317' WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.09614 seconds
Time After: 0.09640 seconds
Memory Before: 4,287.922 KB
Memory After: 4,288.164 KB
